4xq »
https://forums.nicoclub.com/4xq-u207684.html
Sat Nov 15, 2014 8:49 pm
Ahhhh, so shes an Ozzie girl. Heard a lot about those Ozzie girls, have never met one tho.
There are a few things that come to mind here.
- Could be as simple as a loose exhaust pipe or broken hangar.
- Could be a universal joint in the front or rear drivehaft.
- There is a slip joint on the rear drivehaft - if this gets dried out it can cause clunking (driveshaft comes off for this). Most people report clunking at low speeds. Still worth looking at it tho. There is also a grease fitting on the front driveshaft that may need grease.
- Pretty uncommon, but could be a broken / loose rear transmission mount. That sits right under the transfer case on the frame crossmember.
- When you press on the gas to speed up, your transmission unlocks the torque converter. This causes revs to increase. It is possible there is a problem there. Sometimes dirty fluid, sometimes a bad solenoid, occasionally the torque converter itself.
I think maybe have someone look at it and see if there is anything obvious. If you are due for a transmission fluid service, and they don't find the problem, that would be my next move.
