RyanEvh »
https://forums.nicoclub.com/ryanevh-u146906.html
Thu Jul 01, 2010 9:17 pm
I don't remember exactly everything but make sure all the doors are closed properly. I believe you lock the doors once you're inside then stick the key in and out of the ignition 6 times in 10 seconds. The four way flashers should blink and then press a button on the keypad. If I remember correctly that might work.
