Keyless Remote Programming
RyanEvh
Car: 2001 Nissan Pathfiner
I just received 2 keyless remotes from online for my spare keys and there's instructions on how to program them to my pathfinder but I haven't had any luck with them.
The instructions say to lock all the doors and insert the key into the ignition at least 6 times within 10 seconds and then the hazard lights should flash. And then to insert the key and turn it to the ACC position. Then to press any button on the remote.
I've done this multiple times but it hasn't worked yet. Does anyone how to program keyless remotes?
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
There are two different remotes for the 2001 PF. They have the same FCC ID(KBRASTU10), but one says Model/ A, the other says something else (maybeModel/1A or Model/A1) I have the Model/ A which is less common.
IIIRC, there's more to it than what you listed. You have to lock and unlock thedoors with the switch in door at the right point in the process. I was ableto Google up a good set of instructions for programming.
