Keyless remote programming ?? Help
getuaload
Car: Infinity I30T
I bought a remote from ebay for a 2000-2001 maxima / i30.I have a 2000 Infiniti I30 T
Ihave been trying to programm it all morning i have followed the advise on here and still nothing. So i went to the local rite aid and bought a new battery . Since it has no lights on it i thought the battery could be bad. But still nothing.close & lock all doorsstep 1 - key in & out ignition 6 timesthe hazard lights flashed 2xstep 2- turn the key to the acc positionstep 3- pressed a button on the remote and nothing happens do i have to wait for a period of time ?step4- unlock door and exit. remote doesnt do anything ?Any help would be greatly appreciated Thanks JP
getuaload
Car: Infinity I30T
OK i think i found my problem. The remote i ordered was for a 01 model. I have a 00 model. can this be the problem.
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
welcome aboard
i believe you need to check the FCC(?) number on the back of the fob. i wrecked my max 3 months ago so i don't have a fob to look at. just make sure that that number matches on both fobs.
this also highly depends on whether or not you have the original fob. if not, then you might have a mell of a hess on your hands.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
You're doing it right, you're just missing a step.
After you turn the key to Accessory, you need to unlock and relock the doors with the switch on the driver's door. Then you hit the lock button on the remote. If it worked the hazards should flash again. Then remove the key, get out and close the door, and try the remote.
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
Just about any nissan FOB will work (I said just about)
tcatwoman
Car: 2000 I30t
We bought our '00 i30t used, without the remote key fob and just recently purchased a used key fob. I tried the following procedure and had to try several times, step-by-step, but eventually it worked. I think part of the trick is doing step 2 quickly enough. The first several times, I didn't get the hazard light. Just try several times before giving up. Oh, and make sure you have the right 2025 battery in the remote. My hubby had put a 2032 in and it didn't work.
1) Cose & lock all doors
2) Key in & out ignition 6 times
3) Hazard lights flashed 2x
4) Turn the key to the Accessory position
5) Unlock and relock the doors with the switch on the driver's door
6) Press the lock button on the remote
7) Hazards will flash twice again if it worked
8) Remove key and test remote
