paulypotz wrote:One of my keyless remotes does not work... cannot open doors nor start the car... keyless and button feature doe not work but the key provided does...any ideas? btw i charged it for about a half hour and still nothing
Welcome to NICO!
As mentioned above, the key remote does not have a rechargeable battery. You need to replace the standard coin battery that is inside ... I think it is a 2032 coin cell (but may be wrong on that number - check your Owner's Manual!). Try to get a silver-oxide or lithium (rather than alkaline) coin cell battery as they should last longer.
If it still does not work after that, it may need to be re-programmed at the dealer (remember to take all the remotes in, since the process resets all of them at the same time).
Z
