I've searched all over the internet and these are the general instructions:
Everything works fine until I get to step 5 & 6...the hazards don;t flash when I hit the remote button.For OEM stock keyless entry systems 95 < (and above)
1.Get in & lock the doors
2.Insert the key into the ignition 6 times within 15 seconds (taking the key out all the way, then back in).
3.Hazard lights should flash
4.Put key back into the ignition & turn to run position but do not start.
5.Hit the lock button on the remote
6.Hazards should flash.
7.Pull key out and open the drivers door and then close it
8.It should be set
On other forums and threads others are having the same issue - but I never seem to be able to find a solution to why mine isn't programmed?
Any ideas?
Cheers in advance!
