Hello, I have reciently bought a 1996 Maxima 30G. I have found that the keyless entry in not working. I have traced the problem back the some wires that have been pulled out of a connector in the trunk of the car. If you remove the side pannel inside the boot there is a bunch of six wires that run fairly close to where the arial is located. These six wires that go to the control unit for the keyless entry. I have no idea where they go in the connector. The connector has two rows of three holes, six holes in total. If I can only work out where they go I will have the keyless entry system up and running.
Any help would be greatly appreciated. Thanks Dan
