..... Or you can ask me and I will enlighten you.
Type in Q45 remote and see what you get on ebay. There always ones for like $20... They are universal for the J30, Q45, G20, etc.
The FCC code is AZ.......073. Thats all you gotta know, as long as its got AZ in the front, 073 in the end, and is an infiniti remote (says infiniti at the bottom) your golden...
There is another FCC code, az.....078 that I am pretty sure works, but not 100%.
When you get it, it will come with programming instructions, or I will post them. Its really easy.
Ok screw that Ill just post them now!
Open trunk, get in car, lock doors. Insert key in and out all the way in the ignition at least 10 times within 10 seconds. Using the drivers side lock latch, unlock and lock the door, then within 5 seconds press the lock button (big grey one on the top of the remote). The flashers will blink twice.
After that your golden.... Joe's number is 1888-216-5328.
And to think, Im certainly not a freak for knowing all this stuff off the top of my head, am I???
