what will you use to transmit the romote to ??? romot cant just transmit the signal to you power lucks. it needs a transmitor to transmit get it ?
. ANd also the power lucks is hook up to the transmitor so you have no choice but to use the transmitor. the transmitors also is a part of the alarm, remote altena, siren, power lucks so pretty much to my guess you need the full alarm system to work with power door lucks unless you get the cheap power door luck unit which cost 49.99 at an auto store like, AUTO ZONE, NAPA, CHECKERS, etc. GOOD LUCK..
