Keyless entry
sandman614
Car: 2001 Nissan Pathfinder
I have an 01 pathfinder and when I try to lock or unlock the car with the key fob, it rarely ever works. occasionally after pressing the buttons for a couple minutes it will finally work. i just replaced the battery so its gotta be either the key fob itself or something in the car. what do you guys think?
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
mabye the motors that open the locks or whatever are failing.
Pwnin O'Brien
I had this same exact problem with my factory keyfobs. I took it to Nissan and had them look at it, but they just told me that it's normal. I just ended up putting in a remote starter/alarm which locks/unlocks the door perfectly.
hitman1733
Pwnin O'Brien is right on. The keyless entry "brain" is known to go bad. Best bet is to by a keyless entry system and just put it in yourself. I just used a simple one. An Omega DEC-12 or REC-12, I forget. It's pretty simple and you don't need a relay.
