a
R-Yahne_240 wrote:we use a power assisted door lock actuator.... that means when you push the lock button it uses ground to complete the relay and powers the actuator then triggers the passenger side door to lock also
on my car i used an aftermarket actuator cylinoid from best buy ( 15 dollars) and used my factory actuators for the power assisted locks so when you trigger the cylinoid it uses factory components...
hopefully that helps
also i do not believe that diagram is the correct one .. i pulled up the diagram on directed electronics website... at bestbuy and it was not the same as the one you have
