Keyless Entry Range?
herr_jon
Car: 2008 Rogue S
What is everyone's experience with the range at which you can lock / unlock the doors?
I have to be so close to mine that I might as well use the mechanical lock / key.
Anyone else have this problem? I've replaced the batteries in both key fobs and there has been NO CHANGE.
Anyone know where the antenna is for the keyless entry system in the Rogue?
Thanks,Jon
philipa_240sx
Definitely something wrong. I can usually activate mine 40-60ft away.
The keyless entry antenna is under the dash.
boooey
i have found the range to be kind of weak also.
if I have a clear un blocked view to the front of the car, the range isn't too bad.. but if your standing behind your car the range is really poor.
there has also been times when I also have to be really close to the car to unlock.it could definitely be better than it is
Return to “Rogue Forum”
