Keyless Entry (Key Fob) wont reprogram (Cant erase previous ID Codes)
InfinitiFreak101
Car: 1997 J30t
Howdy
I just got a nice keyless entry fob for my 1997 j30. I tried to follow the instructions but after inserting and removing the key from the ignition the requisite amount of times, the car does not flash the hazards, and the fob wont be repogrammed.
http://infinitihelp.com/Owners...2.htm
Can anyone offer advice? Why wont the car flash the hazards after the insertion process?
InfinitiFreak101
Car: 1997 J30t
Nobody? Some automotive genius, please help. . .
The key I have is not the factory origianl but says "For Nissan" the other side says "Curtis Da31". Is that why it wont work? I bought the car used and dont know much about this.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You did unlock and lock the drivers side door manually, NOT using the switch? BTW i often press the buttom multiple times.....
InfinitiFreak101
Car: 1997 J30t
I'll try again , but the problem is in step :
3. Insert and remove the key from the ignition key cylinder six times within 10 seconds.
Before I need to press the button on the keyless, the car is supposed to flash the hazard lights to show the codes are clear. It doesn't do it. Is it because the key I have isn't the original?
elwesso
2007 BMW M Coupe
saw192837 wrote:I'll try again , but the problem is in step :
not its not... your supposed to push the lock button on the remote, and then it will flash to show that the new one has been programmed... BTW in my notes it says more than 10 times within 10 seconds
InfinitiFreak101
Car: 1997 J30t
Wes, Can you please post your instructions?
elwesso
2007 BMW M Coupe
Too lazy to type it up again...
zerothread?id=134751
