Keyless entry fob not working?
00QX4
Car: 2000 Infiniti QX4
I bought a used keyless entry for my 00 QX4 off ebay. I'm trying to program it, but it's not working. Battery is new. Is there a specific FCC number that will only work on QX4s? The FCC id number on the back of this keyless is KBRASTU09. This specific keyfob has the unlock, lock, panic, and trunk button.
asnorton44
Car: 2001 Infiniti QX4
Yeah you can call the dealer they should be able to give you your FCC ID. There are different models that look the same depending on your manufacture date.
00QX4
Does anyone here have a 2000 QX4 with their keyless who can tell me their FCC ID number so I can buy another with that same number so it will work?! Thanks in advance.
asnorton44
What is your build date? This one is on or before 01/00:
http://cgi.ebay.com/ebaymotors/2000-00- ... 1c155bd613
00QX4
my build date i found on the door jam is 12/99
VG33QX4
i bought a kbrastu10 for mine i programmed it like you should and all that jazz the thing is, it works so randomly i gotta press the button 100 times before it will actually work. i went to the auto store where they have those radio frequency testers and it is putting out signal, so evidently the problem is with the car. my buddy has a pathy and his does the same crap.
the keypad you need for a 2000 is
fcc id kbrastu10 AND HERE IS THE MOST IMPORTANT PART MODEL/ A
MODEL A01 WILL NOT WORK PERIOD i made this mistake twice.
00QX4
VG33QX4 wrote:i bought a kbrastu10 for mine i programmed it like you should and all that jazz the thing is, it works so randomly i gotta press the button 100 times before it will actually work. i went to the auto store where they have those radio frequency testers and it is putting out signal, so evidently the problem is with the car. my buddy has a pathy and his does the same crap.
Thanks for the heads up, I will have to email the seller on ebay that I would like the Model/A and not Model A01. He sent me a KBRASTU09, which did not work at all, and was most likely for the G20s or i30s. So i sent it back to him and he said he'll send me a KBRASTU10, i'll let him know it' has to be a Model/A as well. thanks a lot.
