GoNzCiD »
https://forums.nicoclub.com/gonzcid-u118249.html
Tue Oct 21, 2008 10:06 pm
Thanks Toby, It´s correct. If I lock/unlock driver door with the key, It locks/unlocks the other three doors, but if I press the drivers button it locks the other three doors but the drivers not.
The keyless entry I have, has two relays internally so I have 6 wires to combine with the electrical car wires.
I woulk like to put the keyless within add any aftermarket actuator and wire the otrher three doors. It is possible?
I have think this solution: Driver's door have a master actuator, if I can activate this actuator with my keyless entry, the OEM system locks/unlocks the other three doors like I use the key, ist'n it?
Thanks a lot.
