Keyless Entry/Alarm Installs
reodan92
Car: 98' 240sx - Silver moss :)
I was wondering if anyone on here has hooked up there own keyless entry or security system? I just bought a autopage rf-225a system and the local shop wanted $170 to install it. Im looking at all the parts that came with the kit and it looks like a lot of work and an lot of things could go wrong. I was wondering if it was a pretty simple installation for you guys.
Redevil
if you've never done one before then it may take you a couple days to finish. Find someone who knows what they are doing and see if they will do it for cheaper.
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
Pretty easy to install imo.
Follow these two guides. http://www.modifiedlife.com/1991-nissan ... schematic/
http://www.the12volt.com/doorlocks/page2.asp The trickiest part is wiring the door lock/unlock system. Depending on the alarm system you have, one or two relays will be needed. The rest is self-explanatory.
Good luck.
Steady_One_S13
edit: oops. Just noticied you have a 98.
motoman399
Car: 98' wrecked (RHD coming soon) 240
i have done 2 of them on s14's. if you are comfortable with wiring, then its not hard. it looks like a lot there, but just do it one wire at a time. also make sure you solder everything. you dont want problems later on
driftneil
Car: A pile of cars.
motoman399 wrote:i have done 2 of them on s14's. if you are comfortable with wiring, then its not hard. it looks like a lot there, but just do it one wire at a time. also make sure you solder everything. you dont want problems later on
Same here...And I second all of this.....Its really not that hard, go for it. Good luck
motoman399
one other thing, when you do it, go on the12volt site and make a diagram of which wire colors go to what. and void out all the wires on the alarm your not going to use. you will only use about 70% of the wires on the alarm itself.
the alarms i wired were viper ones. so i cant offer much help on that specific one, but still shoulnt be much different.
