MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Sun Dec 26, 2010 6:00 am
It's also possible that your key is to blame, especially if you're using a copy (or even a copy of a copy). I've had problems with my copied keys wearing down over time to the point where they won't operate the doors anymore. If you still have your car's original small number plate (it originally came on a keyring, and is maybe an inch long) the dealer can still cut you a "true" brand new, clean, perfect key from scratch. That may solve your problem. Copying keys over and over again over the years slowly degrades the shape, and eventually you end up with something that doesn't quite work in the tumblers anymore.
