key system error
eclipse95blk
Car: 2013 m37xS
09 FX35S
Anyone found the reason for the key system error light on dash. I know its not the Key Fob battery or the main battery cause they were all replaced and still having the issue. tried resetting computer and nothing. Everything work fine with the key only the annoying dash light. Last option it the dealer, but they may say replace BCM and reprogram
Yoda's Master
Car: 2012 M56
2009 370z
:welcome:
:worthless:
Ilya
I had my fobs randomly flat out die. I had two get two new fobs and a reprogram under warranty. Only way I could start the car was pushing the start button with the fob.
eclipse95blk
Car: 2013 m37xS
09 FX35S
I have everything working key fob does everything it suppose to. walking up detect and turns on puddle light and interior from either side. car start issues other than the warning. Ill try unplugging the BCM for 30 mins and see
eclipse95blk
Car: 2013 m37xS
09 FX35S
bump, Anyone work at a dealership here see this issue.
eclipse95blk
Car: 2013 m37xS
09 FX35S
Finally had the system cleared from my local key guy. BCM had come codes stored.He said most of the time this is a ground issue somewhere on the BCM wiring. He also made me a spare factory key and programmed for 160. same price the dealer was charging me to check and reset the key system.
