Key Stuck in key slot...HELP?!!?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
markaclegg
Car: 2008 EX35
Okay, I am an idiot... I inserted my key, not the fob, the key into the slot in my 2008 EX35 in error. It is stuck and it will not come out even when I open the door and it flashes to tell me to get it out. Any ideas?
Why? Battery was dead and I thought that the slot was for the real key, not the fob.....guess I should've read the manual!
HELP!!!
txgcoupe
Car: 2007 G35 Coupe/ 2010 EX35
Push it in farther.
John
AWGD8
Car: 2008 EX35 AWD JOURNEY
Did you force it in? use a long nose pliers to remove it. Nice to see a fellow Cheesehead here~
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
How and what exactly did you put in the slot?
If you put anything other than the infiniti key you are going to most likely going to need a flashlight and a pair of electronics needle nose pliers to safely remove whatever you put in there.
Be careful the sliding mechanism is not very durable to poking and prodding.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
