Key stuck in Ignition
TyrannicalTy
Car: 1993 Infiniti J30
Hey all,
I was wondering if anyone could tell me if there is an ignition release switch and where it might be located. I can't find an access point under the steering column... Currently, my key has become stuck in the ignition, and will not rotate to the left-most "lock" position. Therefore, I have to pop the hood and disconnect the battery as it sits in the driveway so that the battery doesn't drain out. I believe that my key is simply worn and may have a slight twist in it preventing me from extracting it. If I can find a way to release it, I'll get a new one cut asap.
Thanks in advance.
j30t_Dan
Car: 2009 Nissan Sentra SE-R
This sounds kinda basic.... Not calling you an idiot or anything, but did you try moving the steering column?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I would look at the owners manual or look though the service manual paper copy which should be some where in your vehicle or online version: http://Nicoclub.com/FSM/J30.
But there should be some kind of a release mechanism.
Good luck and welcome to NICO.
TyrannicalTy
haha, Thanks Dan... No, it's not the steering wheel position. Tried all that. I finally got the key out last night though, and the key doesn't look as bad as I thought (still could use a new one). I used a rubber mallet and gave it a few love taps , and it finally came free. I believe my ignition is just getting old and one of the tumblers got seized up. This could possibly be attributed to the fact that it's been as cold as -20 F here the past week. Anyways, thanks for the suggestions guys.
Anyone see any reason not to give my ignition a little lubrication?
GerryO
Car: 1993 J30t
Pearl White
Black Interior
Time for some graphite lubricant. I have a badly worn key, for another vehicle, and it can be removed from the ignition when the engine is running.
Keep the number of keys/the weight of your key ring to a minimum to reduce wear on the ignition.
Original J30 keys are made of titanium, so they don't wear much.
yodawill2000
Car: 94 Infiniti J30
Very LITTLE graphite I might add.To much will cause issues down the road.My Titanium key finally snapped awhile back.Sad day .. lol
Infinitiguy19
What kind of issuies, can it be remove with electrical parts cleaner if too much is used?
yodawill2000
Ive heard of people over doing it and in time it gums up the tumblers.Just a dab will do ya' .
