Key stuck in ignition
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
My steering wheel won't lock and the key is stuck. Can anyone help?it's a 95
audtatious
Jiggle it back and forth as you push in and pull out?
maj Andres
I got it out! My car used to be an automatic and it has this cable that goes from the ignition to uhh.. nowhere so i pushed it in and out several times and the key came out like usual. I guessed I must of did something when I installed my turbo timer.
TougeSlide
Car: Sr powered 240sx
audtatious wrote:Jiggle it back and forth as you push in and pull out?
always sound advice.
