Key Stuck in Ignition - SR swap
ca-jon23
Car: '96 White Zenki, S13 Blacktop
Just did my SR swap with the auto-stick conversion' and the good news is that it starts and runs, so atleast I know most of the wiring is right. But now I can't get the key out. I know it's the shift lock control unit, and I know which one of the three connectors it is by the fuse block on the right side. But since I swaped the starting/charging harness there is nothing to plug back up. My question is can I just jump the connector or is it gonna really screw up something?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
I did the same swap and had to jump the wires where the automatic shifter was. Don't remember which wires though. I just jumped wires until it "clicked"
ca-jon23
I was thinking that. Thanks I'll try it.
ca-jon23
I tried hooking up some of the wires and it didn't work. Now the gauge cluster stopped working and all the fuses are good. Don't know what happened. Any help would be appriciated.
Asia989
Car: 90 s13.4
jus disconnect the box above the clutch pedal
