redmanfx wrote:My key got stuck the same way when the Battery cable connector didn't connect properly with the battery post due to corrossion. Happened only twice and when a new cable was attached it never happened again. Anyway, that's what happened to me.
red
Have you ever had a problem just turing the key after you put it in the ignition? If so, then probably one of the tumblers is broken. I had this problem in my Q. A call to the locksmith, three hours, and about $100 fixed it right up.
Also, it could be that the key release button may be stuck.
