JedCoop »
https://forums.nicoclub.com/jedcoop-u11491.html
Fri Jul 11, 2008 10:48 am
NO NEED TO CHANGE THE COLUMN LOCK!IMOThe key is $150.
Having gone through a lot of key problems, what you need is a brand new key from Infiniti. These things wear, esp. on the '90-93's because there is no keyless entry.
I have three keys for my 1992 Q. One works perfectly. One works about 30% of the time if you use it with finesse. And one almost never works. Guess which one is new?
Also, the key CAN GET STUCK, just like you say. Graphite and non-chlorinated thin spray lubricant (e.g., Green WD-40), some gentle leverage, and a little Zen patience and I am sure you will work the key out. Good luck.
p.s. I also installed a keyless entry on my 1992 to preserve the current new key.
