Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.html
Mon Nov 24, 2008 3:59 pm
One outside possibility is some interlock that won't give you back the key unless the tranmission is in the right gear. My 'vette has this. My '01 PF witha manual transmission does not, and I don't see any evidence of it in thefactory service manual.
You do NOT want to put oil (WD40) in a lock. It will eventually attract enoughdust and dirt to gum things up. You won't get powdered graphite anywhereinteresting with the key in. The answer is graphite in a liquid suspensoin fromyour local hardware store (I think mine came from ACE). Remove the bottomplastic bezel under the steering wheel, put a bunch of paper towels underneath,If you have a really cherry ride, put an old beach towel on the carpet, thisstuff goes everywhere. Then squirt some in along the key and jiggle the key.The liquid solvent will eventually evaporate, leaving just the good graphite.
If that doesn't fix it, it's likely the cylinder is busted, and you'll need a newone. Dunno if Nissan can supply one matched to your current keys, butthat would be a good thing, the keys are pricey. Or maybe you can get agood locksmith to rekey the replacement to match your keys.
Chuck
