Key Programming Instructions attached. (Infiniti M)
mixter
Car: 2003 M45
I searched for this in the forums, but had no luck. Hopefully this will help someone else.
However, I'm just now finding out that if you have the "immobilzer", the programming instructions work for the remote functions, but it will not start the car. I guess I'm going to the steeler anyway......
KEYLESS REMOTE PROGRAMMING INSTRUCTIONS 2002 -2004 INFINITI M45 2002-2006 INFINITI Q45
A MAXIMUM OF 4 REMOTES CAN BE PROGRAMMED
GATHER ALL REMOTES & CLOSE ALL DOORS
INSERT & REMOVE KEY REMOTE FROM IGINITION MORE THAN 6 TIMES WITHIN 10 SECONDS
INDICATORS WILL FLASH 2 TIMES
INSERT KEY REMOTE INTO IGNITION AND TURN TO ACC
PRESS ANY BUTTON ON FIRST KEY REMOTE TO BE PROGRAMMED
INDICATORS WILL FLASH 2 TIMES TO CONFIRM CORRECT PROGRAMMING
OLDEST KEY REMOTE CODE IS NOW ERASED
TO PROGRAM NEXT REMOTE KEY ?UNLOCK THEN LOCK CAR USING LOCK/UNLOCK SWITCH ON DRIVER?S DOOR CONTROL PANEL ?PRESS ANY BUTTON ON 2ND REMOTE KEY TO BE PROGRAMMED?.INDICATORS WILL FLASH 2 TIMES TO CONFIRM CORRECT PROGRAMING
REPEAT PROCEDURE TO PROGRAM REMAINING KEY REMOTES
TO EXIT PROGRAMMING MODE ? OPEN DRIVER?S DOOR
CHECK OPERATION OF ALL PROGRAMMED KEY REMOTES
FOR QUESTIONS REFER TO YOUR OWNER?S MANUAL OR CONTACT YOUR LOCAL DEALER ? CAN BE PROGRAMMED WITH THEIR DIAGNOSTIC EQUIPMENT
infinititech1
you missed a few things
and this works on just about every single infinti and nissan.
after you close the door you have lock it...and after you see the hazards flash you have to turn the key to ON and not to ACC, the hazards will blink to confirm its been programmed
postal_m35
Car: 06 infiniti M35
does that apply to the 2006 m35/45 also? i just paid like 30.00 to have an extra key done.
infinititech1
The I-keys are different and have to be programmed with the consult (nissan diag computer)...
postal_m35
ok then, thanks for the info
GNR4ALL
Car: 2003 M45 Black Stallion
Is there any way to program the 2003 m45 key to turn on the ignition as well wihout going to the dealer?
infinititech1
i think you IMed me..but no...has to be done at the stealership
lolopafundi
Car: infinity
I need to know how to progranm the new keyless remote for the Infinity G35 X 4 doors sedan? ANy one ???
ClutchKick
Car: S14 Y34
I was not aware this worked with any key remote other than the regular ones... I didnt think this worked with the ones that have the key insert like the one on my m?
hrm....
NO1B4ME
Car: Infinity M35S
I had a neighbor(Infinity Master tech) program a key i bought from Ebay. He said the remote was bad. He programmed it several times with no luck. The odd thing is he said it would work to turn on the car if placed in the slot, but owuld not open the doors.
I Emailed the guy i bought it from and he said it should work as he sells a ton of them.
What do you think?
christopher82
Car: 2003 Nissan Pathfinder
Hi guys I'm a new member to the pathy family. I just got new remotes and I have the programed.Does anyone know if you can program the remotes to make the lights blink when locked and unlocked
szh
Car: 2018 Tesla Model 3.
christopher82 wrote:Hi guys I'm a new member to the pathy family. I just got new remotes and I have the programed.Does anyone know if you can program the remotes to make the lights blink when locked and unlocked
Welcome to NICO, but I think you might have better luck asking your question in the Pathfinder specific forum!
Click here: zeroforum/37 and post your question again. Thanks!
Z
szh
lolopafundi wrote:I need to know how to progranm the new keyless remote for the Infinity G35 X 4 doors sedan? ANy one ???
Welcome to NICO! But, I think you will get a better answer from the people and Moderators in the G35 forum at NICO. Click here to get there: zeroforum/102.
Z
FlyinHuey
Just bought a 07 G35 with one key and a keyless remote. I figured out how to program the remote thanks to your post. 2 questions:If i buy a blank transponder key off of ebay how can I program the key myself?
what does (fob) stand for
antzrus
Car: '06 M35x Premium/Obsidian/Bourbon/
Rosewood/XM/Tint/
ClearBra/SteelSkidPlate/Genuine CoCo Mats/Michelin CrossClimate2/Nav Hack/M-1
FlyinHuey wrote:...what does (fob) stand for
fob (fŏb) n.A small pocket at the front waistline of a man's trousers or in the front of a vest, used especially to hold a watch.
A short chain or ribbon attached to a pocket watch and worn hanging in front of the vest or waist.
An ornament or seal attached to such a chain or ribbon.[Probably akin to Low German Fobke, small pocket.]
A more popular meaning over time is that a Fob has come to mean something attached to your keyring; such as the radio transmitter that operates our doors et al.
rliss
Car: 2008 Infiniti M35
Does anyone know about programming a key for an 08 Infinity M35? I want to buy a new key as a spare from Ebay but have been told by a car key specialist there could be a problem even if it is a new key because the transponder code may not match that of my vehicle even if I get it programmed by the stealer. Anyone know about that?
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
rliss wrote:Does anyone know about programming a key for an 08 Infinity M35?
We only deal with Infinitis here.
Poyzinous
NO1B4ME wrote:I had a neighbor(Infinity Master tech) program a key i
I think you and Rliss should make a few corrections in spelling Stand behind your car and read what you see, and look at your kick plate when you open the door, and the vehicle registration too. Somewhere, there is a 'y' that snuck in where it shouldnt be.
rliss
Thanks for the great reply pal! Very helpful. We really need more people like you on this forum (not). GET A LIFE you jerk.
bredtime
Car: '06 Infiniti M45 / '08 Infiniti QX56 / '08 Acura TSX
rliss wrote:Thanks for the great reply pal! Very helpful. We really need more people like you on this forum (not). GET A LIFE you jerk.
Take a chill pill man, he was just kidding around!
rgb129
Car: 2008 550i sport
RIP 2006 M35x
Re
You need to relax a little. He was just joking around...and you did spell it wrong in your post and in your acct info. Not to mention, your question was answered further up in the forum...you need to go to the dealer
Poyzinous
Ok, here's your reply. The fobs all have their own frequencies. You need a specific one for the M, part number 285E3-EH11A. You can buy the fob anywhere, but it needs to be programmed at the dealer, along with any other keys you have.
rliss wrote:We really need more people like you on this forum (not).
I happen to be quite helpful here actually, look at my 1420+ posts. My knowledge, expertise and inside info has been beneficial to hundreds.
rliss wrote:GET A LIFE
I have a life. A quite nice one, for the most part. One aspect of my life is Nico, where, as mentioned before, I do a lot. I am well known in practically every section of this website for being fun and playfully entertaining with our members, and contribute mightily. Check my profile and the almost 100 threads I have made to inform, assist, entertain and enlighten the thousands of members who enjoy this website.
rliss wrote:you jerk.
You called me a jerk, I am sorry you feel like that. My apologies for hurting your feelings in whatever way. Now how about you fix your "Infinity" spelling so you can stop hurting mine. If you refuse, well I'll mail you a series of 'Y' letters I'll swipe from unsuspecting toiotas and you can attatch them to your car. to Bredtime and rgb129
rliss
OK Poisonous (gee there I did it again- sorry about that) now that you are playing nice lets try this again. I understand the FCC number and the IC No. for the fob/key set have to match the required numbers for the vehicle key. I was also told that there could be 3 different transponder programming frequencies that are used to program the fob/keys for the 08 Infiniti M series (apparently there is a new programming scanner? or procedure for 08 which is different from that used for programming the 07 and 06). The question is whether any keys offered on Ebay will be usable for an 08 Infiniti M or not, and if so what to look for. Does anyone have any experience with this or with programming fob/keys for an 08 vehicle?
Poyzinous
the key and fob for 06,07,08 and 09 M models are the same and all interchangeable. Fix your profile info. You dont drive an infinity
szh
Poyzinous wrote:Fix your profile info. You dont drive an infinity
I fixed it for him.
Z
Poyzinous
yay!
rliss
Thank you. Hope everyone is happy now.
rliss
Another thing. I was told for the 08 (don't know about previous) that if a new fob/key is programmed to the vehicle all other fob/keys for that vehicle have to be reprogrammed at the same time since a new key code will be generated. Any comments?
antzrus
Rosewood/XM/Tint/
rliss wrote:Another thing. I was told for the 08 (don't know about previous) that if a new fob/key is programmed to the vehicle all other fob/keys for that vehicle have to be reprogrammed at the same time since a new key code will be generated. Any comments?
Yes, this is true; all reprogrammed the same. Geez, I'm really sorry you figured out that most of us herein are just a bunch of turkeys and not worth your wrath. Cuz I just love really hot fla me wars.
rliss
I have no truck with turkeys around Thanksgiving. Kind of enjoy them in fact. Especially when I cook them.
Modified by rliss at 7:00 AM 11/14/2009
