Key issues 1991 Q45
infinq45
Car: 1994-1991 infiniti q45
Hi I own a 1991 q45 with only 50,000 mile on it great car but i an having issues with the locks the key will not insert all the way it sticks I have lubed checked the key for burrs have tried the key in my other q and it slide in ok the glove box key from my other q works fine that is it will insert all the way . the issue is getting worse to a point where the car is going leave me stranded anyone have any ideas?? Ihave checked with the dealer a complete lock set is no longer available
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
goody90q45
Car: 1992 Infiniti Q45 (sold)
Try blowing out the keyhole with compressed air and see what comes out. The link Brian posted saves you about 25% off MSRP. Call IOS and give them your VIN and they can cut a key and send it to you for cheaper than your local stealership.
Q45tech
Pay an expert LOCKSMITH to clean and rebuild locks.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
maxnix wrote:Try http://www.infinitipartsusa.com
Call them.
They told me that my key code was no longer in the system when I gave them my VIN.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
infinq45 wrote:Hi I own a 1991 q45 with only 50,000 mile on it great car but i an having issues with the locks the key will not insert all the way it sticks I have lubed checked the key for burrs have tried the key in my other q and it slide in ok the glove box key from my other q works fine that is it will insert all the way . the issue is getting worse to a point where the car is going leave me stranded anyone have any ideas?? Ihave checked with the dealer a complete lock set is no longer available
The same key is giving you trouble in both doors? Strange.
I have a door key and a different key for the ignition. The ignition key can unlock the driver's door if I insert it just right. But the same key won't open the passenger door or the trunk. Conversely, my door key won't turn in the ignition.
Same with the valet key. Good for doors, no good for ignition.
Hope you can get this sorted out. I think Tech's method may be the best route after Goody's.
infinq45
thanks to all for your responses about my key issue i will look into trying some of the soulitions yes i am having issue with all the locks on the car except the glove box
OwnerCS
Infinq45 - I tried to reply with an answer to your PM about my 91's interior and I cannot reply as your PMs are currently turned off.. :-(
Please turn on your PMs so I can reply.
