did you try to press the lock button? Well changing the motor should not affect your key. If you cant get it to work go to 'pick-a-part' and get a different one.aaronscomp wrote:Ok the other day i helped my freind put a dual cam in his car now that we did that his key gets stuck in the ignition any help would be appreciated
I did some research for you and that is problaly what the problem is. I didnt think of that because I guess mine was unhooked by the previous owner lol.whyteboi wrote:That's prolly because you wired it up correctly but if you for get the neutral safety switch(i belive that's what it's called) then the car will think it's still in gear and not give back the key
wow sounds crazy. I hope you get her workin.chalmer240sx wrote:that makes sense, i totally forgot about that. mine was removed because my transmission was all jacked up on the gear box and when u pushed the stick to far up it wouldnt start and it only would when my friend did some crazy ritual to start it lol
wow I hope when I finally get around to get around to swapping mine I dont have to deal with stuff like thatchalmer240sx wrote:yea we did we had to pull the e brake 3 times put it in park crank it, put it in neutral crank it, put it in first crank it, 2nd crank it, 3rd crank it, put it in park crank it and it started right up lol
