torres336 wrote:Hi.....I'm new on this forum and I have one question to any body that can help out.....I lost one set of keys of my 2011 Infiniti G37 convertible....i bougth one set but i don't know how to programming this remotes....I hope someone can help me out on this problem.....Thanks....Paul
1 Sit in the driver's seat and close all doors. Lock all of the doors using the power lock switch on the driver's door.
2 push start button (do not start the car) at least six times in 10 seconds. The start button must be pushed on and off fully each time. If you have done this step successfully, the hazard lights will flash.
3 Push start button to the "accessories" setting.
4 Press any button on the remote within five seconds of putting in the key. If you have done this correctly, the hazard lights will flash again. That remote is now programmed into the system.
5 Unlock and then lock all doors using the driver's-side lock switch. Press any button on a new remote within five seconds to program that remote in to the system. Repeat this step for every remote, including any existing remotes that were programmed before this procedure.
6 Turn the ignition to the "Off" position to end the programming mode and unlock the doors using the driver's-side power lock button and open the driver's door.
good luck & happy new year
