macgiver wrote: ↑Fri Sep 27, 2019 8:04 am
Not being a wiseguy , but what's overlooked : Fob DID work previously - OK , BUT you have'nt said and one really would'nt know if the KEY programming had worked ? when ? how long ago ? Like did you program key it last month ? 2 weeks ago ? or 2 days ago ?
I've seen (mine won't register the key) many a situation where the key recgognitioning to "register" each key insertion is faulty. My case, key doesn't register.
You may TRY to insert the key 1 or maybe TWO more insertions than your doing - even up to ,say , 15 or twenty in the specified time period . Figuring that some of the " un-recognized" insertions DON"T COUNT??
So in other words KEY re-programming possibly faulty - discovered NOW.
AND you may NEVER know nor find out what exactly "dropped" the FOB capability ? Unfortunately .
Thanks for replying. Wife's car so I don't drive it or use the accessories much. She mentioned it to me yesterday but said that she doesn't use the fob all the time, doesn't lock the car at work, nor when it is in our garage
. So, the history of exactly when it stopped working is uncertain.In other words, was it not working before I did the switch repair or did I do something during that repair to cause the problem? I dunno. BTW, the 1st thing I did was check the 3V coin battery; was slightly over 3V. Then I began the programming effort.
To recap, I believe you are saying that, in your case, the programming feature doesn't work either & that maybe it is hopeless (on an older car like this) or not worth the $ to track it down, yes? Was hoping there is an overlooked solution so I hope someone who had the problem & resolved it will get back to me. Thanks again.
