Clyons0203 wrote:Tried both procedures multiple times, with two fobs, both with new batteries. One fob beeps, the other doesnt
Neither work on the car.
When it says close and lock all doors. Do i have to open the close all doors? Manually lock them?
Do you have an original FOB from Infiniti? By the way my J30 is a 1997. My OEM FOB never beeped before even when the battery was low. When it seemed the FOB wasn't working even close to the car I replaced the battery in it & never needed to reprogram it, I did that twice.
I opened the trunk with the lever on the driver's door & lifted it all the way open, then got in the car & used the "lock all doors button" on the driver door panel & then proceeded with the directions.
It took me a couple of times to get it right.
"7 - Test transmitter for function."
I got out of the car & manually closed the trunk before step #7 & the FOB worked fine.
I had to read & try the directions several times to get it right.
Modified by J30inthe sun at 8:06 PM 3/14/2009
