key code
Pr0ject_S14
Car: 95 240sx s14 sr20det
well I lost my key to my 95 240. I called the nissan dealership but they said that they don't have the code for 96 and under vehicles. I was wondering if anyone knew where I could find the key code?
s13redtaz
Car: 91' S13 Donated and gone..., 96' Toyota Avalon (DD), 92 coupe*SOLD*,92 5 speed Hatch
normally its in your glove box on a sticker or something. it will be someting like x followed by 4 numbers. if not they can use the VIN # to pull it up.
Pr0ject_S14
thanks, I am going to go check the glove box. Has anyone found the key code in there 95 240 by checking in the glove box?
s13redtaz
any luck?
Pr0ject_S14
ok well I didn't find the key code in the glove, ashtray or center console, but I was able to contact nissan customer service and they were able to send the key code to the nearest dealership. The dealership will never tell you that you will be able to get the key code for 95 cars and older they will tell you to go to a lock smith, which will cost $200+ for them to make the key. So the easiest and most inexpensive way to get your key code is to call up customer service and they will update your keycode in there system.
