key broke in door hole HELP!
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
like the topic says.
the key is about 75% broke into my driver side door hole and i dont know what to use to get it out.
i was thinking crazy glueing the key and putting it back in and trying pulling it out but then seems kinda risky since it might get mess up more.
HELP!
thanks!
Hijacker
Car: '92 240sx Convertible
'94 F-150
If any of the key is poking out, grab it with vice grips and pull it out. If not, your best, and safest, bet would be to call a locksmith.
240sxvaj
i can see the key but then its not out.
PISS ME OFF!
5upra
Car: S197
get peice of wire and try soldering to the key...but definitely don't load with solder! just being creative here.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
If theres a knub of the key exposed grab some needle nose pliers and pull it out.
240sxvaj
nope
when i poke the key hole i can see the broken keybut when im just looking at it with out putting nothing in the key hole it looks ok like nothing is wrong with it.
so basically its stuck in there
Yaezu
Used a jig saw blade....modified it to make it thiner. If anybody needs help I will help by sending pictures. I saved $100.00 on a locksmith.
trcomp
Car: 1994 J30
Get a wire fishhook, gently straighten it with pliers...Insert end with barb over or beside key...As soon as barb catches gently slide out key til you can grab it with the pliers...Keep trying you'll get it...
240sxvaj
Yaezu wrote:Used a jig saw blade....modified it to make it thiner. If anybody needs help I will help by sending pictures. I saved $100.00 on a locksmith.
hook me up with some pix.......
BMAR240SX
Car: 1993 Nissan 240S Coupe
Cant you use a magnet?
240sxvaj
BMAR240SX wrote:Cant you use a magnet?
nope!
75% of the broken key is inside
when you look at it from the outside you cant even tell that its mess up til you poke it or something
