Kept A/C or not?
nwmrkt
Car: S13
Im just curios...to those that did the swap did you keep the a/c? remove it, remove other stuff too (what?)
CoupedUp
Car: 1993 Coupe
I removed the A/C Lines, A/C Condenser, A/C Pump, A/C Bracket and A/C Evaporator. I may have removed upwards of 50 pounds but my god, I live in Oklahoma and i do wish i had it. but i guess its bareable. Im moving to michigan soon....sooo....doesnt matter too much.
austins240
Car: 93 240SX HB, 89 Rolla GTS
keep it. but replace the seals and upgrade to R134a if you haven't already while the engine is out.
working on A/C with the SR installed FTL.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
I don't have it, but I did want it. The shop was supposed to fab a bracket to use my SOHC compressor with the SR, but instead they tried to find one instead of making one and waited till the day I went to pick it up to tell me that they couldn't get done. So now, I have to wait until I feel like bringing it back (~100 miles from my house) to have them run custom lines and use the SR compressor, etc. Probably wait until next year since it's not my DD, or I my just keep it off. I dunno.
MadcowCoupe
Car: 1993 Nissan 240sx Coupe
i have a/c. swapped out the sr compressor for a ka one. bent and fit the ka lines like stock. vac charged the system. blasting cold *** a/c!stock s13 blacktop Sr freezing cold.
CMG
Car: 1989 240sx Hatch w/ Redtop
If the car is a daily driver and you like little luxuries, keep it. I removed every single part asociated with AC in my swap, and lost a lot of weight and the bay has more space. But I live in CA, and I never use AC on any of my cars, so it was only natural.
Sil80sushi
Car: 90 240sx
i kept it but im in Texas and the heat ssuuckkks Also its kinda nice for the girls...........
CoupedUp
Car: 1993 Coupe
Girls? *rolls eyes*
Thats why they have cars too.
Sil80sushi
Car: 90 240sx
if your chicks car was as flashy as mines youde be driving your car alot more
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
Removed a/c. Other than no hassles and lost extra weight the compressor engagement is hard on bearings unless you have an ATI SD. Take apart any a/c'd SR and you'll see a drastic diff between front, mid, and rear main bearings. A lot of this is due to the clutch engagement of the compressor.
If your hot just drive faster!
homeslicej2
doridori23 wrote:Removed a/c. Other than no hassles and lost extra weight the compressor engagement is hard on bearings unless you have an ATI SD. Take apart any a/c'd SR and you'll see a drastic diff between front, mid, and rear main bearings. A lot of this is due to the clutch engagement of the compressor.
Really? huh.
spider_slayer
Car: S14 240SX
S13 240SX
didn't know that. it makes sense though i guess.
i jsut took mine out. A/C is for women. i jsut have my girl drive.
nani
Car: 89-240sx
FACK AC, if its too hot get a small fan
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
I wired up my A/C but like Homegirl () I need custom lines and I'm too lazy to have an AC shop do it.
homeslicej2
redtop91 wrote:I wired up my A/C but like Homegirl () I need custom lines and I'm too lazy to have an AC shop do it.
Ryon, you had a DOHC so why didn't you just hookup your compressor to the SR's bracket? Not the homegirl stuff again
Sil80sushi
Car: 90 240sx
Well **** it call me a girlie but im a girlie that aint gona smell like sweat and another thing Sex+Hot weather= drowning in own sweat
homeslicej2
My 240 is no longer my DD. I got tired of the little problems that kept cropping up after my sh1t was "professionally" installed and bought a stratus for my daily. I just tinker on the 240 and drive it 1-2 a week, so if it's hot as ballz i drive the stratus. I'll get a/c back in it one day, but probably not until next spring.
redtop91
homeslicej2 wrote:Ryon, you had a DOHC so why didn't you just hookup your compressor to the SR's bracket? Not the homegirl stuff again
Ionno. Explain yourself white man!
homeslicej2
shady240
Car: S13.5 SR20DET
i got rid of mine, yesterday/the day before as a matter of fact. figured might as well rip it off before i swap the engine in.
duffman1278
Car: 89 240sx Hatch, the wildcats!
I took mine off mostly for 3 reasons. 1: my daily driver has no A/C. 2: I'M IN CALI! 3: Didn't want to deal with the lines for the A/C and all that junk. Besides, its a luxory item in my view. Also, if you remove it u'll notice how heavy all the things are together. the compressor and bracket are pretty dam heavy.
