sckeith wrote: I just bought a Kenwood 5140 Nav unit for our Rogue. I was wondering where you folks who have this unit are placing the antenna for it. I understand it stays inside the car but I don't like the thought of it just sitting on the dash.
As to mounting the GPS antenna... although I have yet to install a Nav in my Rogue, in my wife’s Acura I ran the GPS antenna wire behind the dash, up and inside the passenger side window pillar. Then using 3M double sided tape stuck it in the very corner of the windshield where the pillar meets the roof. We never even notice it.
Although I'm sure you're referring to the GPS antenna and not an aftermarket radio antenna... for the radio antenna (depending on your factory radio config) I used an aftermarket antenna adapter cable like this one that allows you to plug into the Rogues existing wire harness so you can use the vehicles existing roof mounted antenna. http://www.installer-parts.com...-ni12
