I understand.. The heat sink mesh is a copper woven fabric attached to an aluminum heat sink body I'm trying to figure out how hot it would get inside there still or if the heat sink design and material fabric dissipates the heat. I found a few scholarly articles. It would be a risk to enclose everything altogether. I suppose the next question is asking if this would void their 2-3 year warranty. :PTeknical wrote:I would advise against enclosing that mesh/cloth heatsink within the housing as shown in that video. They will be almost completely ineffective at dissipating heat. I think you'd want to run them out of a hole. I've never seen a heatsink design like that, and I have a lot of experience in the area.
To answer your question, these bands will be isolated in most applications and it will not be an issue, you just want to make sure that you “fan them out/spread them” as much as possible to dissipate the most amount of heat.
These are rated at 120F with constant use, wiring and OE headlight assemblies are rated at 170F and in most cases our LED runs cooler than most halogen bulbs.
Thanks for sharing your experience, and especially for the pics.Eamess wrote:I ended up buying two different fanless LED kits to do some comparisons, since I was feeling extra curious..
--R4 Slim 60W 7200LM LED Car Headlight Philips Chips H11 Bulbs - Released June 22, 2016 (Made in China)
-- Putco 280011 Silver Lux H11/H8 LED Headlight Conversion Kit high-power Philips LumiLEDs with 4000 Lumen - Released January 21, 2016 (Made in USA)
First thoughts: The R4 had high beam chips and rated at a high lumen and has recently been released, so that supposedly meant they would be brighter and (better?) on paper. I'm still wary that they were made in China. The Putco brand has good reputation for making official products for Ford and GM and their online support has been very awesome. R4 were much cheaper and Putco cost about 4-5x than the lights. So, I'll just buy both and compare..
Thoughts on Installation: Straightforward and everything fits well within the housing of the EX35 headlight assembly behind the dust cover.
Results: I decided to aim them a group of mail boxes:
R4 (Sorry a bit blurry)
Putco
The pictures didn't really help much in comparison and the results were received best from driving. The Putco LED were brighter than the R4 and made my transition from the stock much easier. I drove around with the R4 and commuted to work and such and it was difficult to get to used to. I thought maybe the beams were off-target, which could be that they needed to be adjusted. Both lights could be adjusted, so this may affect the tested. I didn't have access to a garage or wall so I wasn't able to calibrate the lights.
In the end, I'm sticking with Putco for my lo-beams. I decided to keep the R4 for high beams, which ended up being good enough. I hardly use my high beams anyways. Overall, I'm pretty happy with my setup.![]()
Links:
https://www.amazon.com/Putco-280011-Sil ... silver-lux
https://www.amazon.com/Racbox-Headlight ... B01HET0586
My next upcoming changes will be the Parking Light Lamp with Philips Xtreme Vision 360 LED 6000K and the fog lights with Super White 6000K 100W LED Samsung 2323 Projector Fog.
Any photos? They look nice on the outside. How was the install? Did it require any modifications for it to fit? I'm wondering if it'll be noticeable from the 6000K lights. The warmer toners were bugging me when they were not similar. :Pjakenbake wrote:I used these for the fog. A ton brighter than just upgrading the bulb.
https://www.theretrofitsource.com/compl ... b-led.html
Eamess wrote:Putco has been very responsive and helpful. They recommended their Silver-Lux line (released 2016) and the install is quite good:
Looks like I'm going to test it and provide updates when I get a chance to order...
I'm checking to see if I'll need the anti-flickering harness or not.
Eamess wrote:I haven't tried it without the anti-flicker harness. It came with it and I ended up putting everything into the lighting assembly and closed the it off with the dust cover. I haven't had problems yet (knock on wood).
It may be worth a try as I'm hearing how it may not beed needed.
