KEMP's Build Thread.
KEMP
Car: 1990 240sx CA18DET
So my build is coming along quite smoothly, not too bad, the only thing thats being a b*tch is getting the crank pulley back on(shed some light if ya can), but i figured i would make a build thread like i hve for all my other cars. pics will come tomorrow.
My build consists of the following.-Block decked and bored .020 over-wiseco 8.5:1 pistons, with a head and block deck to equal out around 9:1 compression.-cometic head gasket-arp head studs-ACL race bearings-all new seals, gaskets, and nice black block and polished pumps(water/oil)-oil filter relocation with hard rubber lines and black AN push lock fittings.-Battery relocation.-Butterfly delete, with gasket matched ports.-window welded trans mount until i get my nismo.-sand blasted and wrinkle coated valve covers.-E-mance ECU-Spec stage 3 6puck-resurfaced flywheel(looks great)-new throwout and pilot bearing.-blood, sweat, tears, gasket remover, and money(lots of it)
As of now the motor is on the stand with the head all torqued down and pulley half on, the intake mani. will be on tomorrow with all new gaskets and put into time. then hopefully the motor will get the flywheel/clutch/trans tomorrow, and the have the motor dropped in and start routing the oil lines.
updates to come, someone try and give me some help on getting this crank pulley on please, thanks.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
my crank pulley just pushed right back on when I used the impact gun. assuming you line it up right and have the timing belt guard (I guess u call it a sealer maybe?) on the right way.
sounds like it is going go..........
you know what everyone is going to want
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
I require pics or ban.
wynnEZ
Car: 90 240 CA POWA!
No joke where the pictures!
KEMP
im goin to go take pic now, lol
hold on.
KEMP
here they are, some are crappy, and the internal pics are on my phone
Heres the mess
Turbo
old talon block i snapped a pic of for fun
Nice shiny piston top
Ring land pics
Exhaust
Oil cooler lines/fittings
Hockey puck window welded mounts with washers/bushings
Battery
Death count on my sterring wheel, haha
Interior pic
Butterfly Delete
Filter relocation
Machined Flywheel
Clutch, mad tyte tow hook, and cigarettes, which have helped alot
meminto
Car: S13 Silvia CA18DECT
Nice one, good work...
Although blurry I assume the pic is of the old ringland area, it looks quite cactus..
Shouldnt have too much drama putting the crank pulley back on, check to see if you have mounted your woodruff key correctly (the half moon shaped metal thing on the crank)..
Good luck with it!
KEMP
thank you, i got it lined up last night and impacted her on
shmex
Car: 1990 CA18DET Hatch, 1992 Stock Coupe
Lookin niiiice dude. Can't wait to build my ca, once I have funds finally.
KEMP
total cost of build, minus fluids and small stuff was around $1900
zero_gripS13
Car: soon to be 95 s14 hopefully
KEMP wrote:total cost of build, minus fluids and small stuff was around $1900
nice lol im at like 3k.. just in motor ... 5k in other stuff probably.
1150 machine work540 pistons rings75 rod bolts200 gaskets130 oil pump30 water pump150 turbo170 timing set
list goes on lol... cant wait to get her finished taking me forever cause one cyl getting sleaved and no one makes sleave but on company in cali had a custom one done and buyer flaked or something so my machinist got it they didnt ship it so he called b****ed and itll be here in 3 days.. should have block back next week. hope we both have good luck and get our s*** running good. even though i have yet to even swap the motor in yet.. lol.
KEMP
sleeved? why.
and i got alot of my stuff at a discount price, im good friends with a local performance shop owner. knowing people FTW!!
zero_gripS13
it in my thread the whole story basically motor sat with head gasket blown either in japan or states i dont know.. cyl 4 was rusted and pitted .. .040 overbore didnt fix it so he has to sleave it and redo the cylinder .. i wasnt taking a risk not getting good ring seal so yea waiting on that.
KEMP
its alive!!!
float_6969
Awesome! Did you drive it yet?
boost_boy
zero_gripS13 wrote:it in my thread the whole story basically motor sat with head gasket blown either in japan or states i dont know.. cyl 4 was rusted and pitted .. .040 overbore didnt fix it so he has to sleave it and redo the cylinder .. i wasnt taking a risk not getting good ring seal so yea waiting on that.
You should've gotten a rebuildable block. But I hope everything works out for the better. "Kemp" congrats on getting your lump up and running. Now seconding the question from the parts hoarder, did you drive it yet?
Dee
KEMP
yes i have, it offically has 287miles on the new motor.
it runs amazing, the clutch is sick, and chatters like a b*tch cuz of the 6puck stage 3 spec, it chirps tires leaving a stop sign, haha
i love it, it should see around 20psi once it gets broke in and gets the volvo fmic.
bentvalves
Car: 89 Silvia K's
dont be too easy on it during the break in period now.
zero_gripS13
boost_boy wrote:You should've gotten a rebuildable block. But I hope everything works out for the better. "Kemp" congrats on getting your lump up and running. Now seconding the question from the parts hoarder, did you drive it yet?
Dee
whats the difference between a different block and a sleave?i could of sent in my other block but he said hed sleave it and cut me a deal so i figured why not save my other block for another build.
KEMP
really?
ok, its got around 300 miles today, so i threw a few pounds at it and it felt sooooo good.
ca18detgabby
03 Infiniti G35
glad to hear you are rockin
weather finally good enough up there to let you really drive it? its hot as shiz here.
bentvalves
Car: 89 Silvia K's
I hope you didnt drive it in vacuum that entire 300 miles.
yea man really, no joke throw some boost at it to get those rings pushing out against those cylinder walls.
zero_gripS13
yea do some decent throttle accellerations in 2nd or 3rd for a few secs then let it decellerate then repeate..
u need to load the motor to get the rings to seal good.. but if u didnt start this process early its a lil too late buy u need to run it harder than u obviously are.
dash
Car: s13 ca18
KEMP wrote:should see around 20psi once it gets broke in and gets the volvo fmic.
20psi thru a plastic tank volvo intercooler, ok ?glad its running good
KEMP
ive been giving it gradual boost, it spiked about 18 tonight and killed tires, felt good, but not safe in my mind without my intercooler.
and the volvo fmic's have been ran at 20 without problems, do you not suggest the volvo fmic for now?
r34 gtr
hell, our Volvo ran 19psi for years and years through the stock intercooler with no problems.
KEMP
2.5in thick 8inch tall fmic wnet on last night, stacked it right between the radiator and all piping is in the bya, it spools quite fast, and gained power, i went and picked up a brand new HKS SSQV at a local shop and got that all on there, ill have pics up tomorrow.
25PSI is feeling amazing!!
boost_boy
KEMP wrote:25 psi is feeling amazing!!
Careful Jr. . Don't go getting boost crazy and thinking you're protected with those wiseco pistons. My sig is not sarcasm, but the truth. You saw what happened to your stock pistons? It can happen to those wiseco slugs as well. High boost always feels good to the driver, but the engine suffers. Question for you: What makes you feel comfortable at running anything more than 10psi of boost on your brand new engine. Your parts list said you have an E-mance ecu? Or did you mean to say E-manage? What have you done for injectors? And lastly, the car has never seen the dyno yet sooooo, do you have any idea where your timing is at under load (not your base timing)? Or even your injector duty cycle?
Not trying to bust your chops or anything, but I would hate to see you damage your engine and end-up like so many others (sell or rebuild again) because you failed to cover the basics with this motor. The CA is no 4G6X or an SR20 or even remotely like the KA. It doesn't like the things those motors benefit from, but it loves boost and it will take what you give it. And will almost certainly puke oil when you fail to feed the beast correctly .
Dee
KEMP
the emance ecu is the same tune the tuner had on his dynoed setup, which is literally identical to my set up, even down to turbo size and everything. i have recently turned boost to 20pounds, and still pulls great.
the tune is the same tune the guy put down 400whp on, but i do need to get on the dyno i know, and i have 444 injectors, base timing is 15*, and the car runs rich as hell all the way to red line, rich enough for me to see smoke.
only thing about checking timing under load on the dyno, is that it is almost impossible with our ecu's not having consult, or any tuners with any way to tune it real time.
how would you suggest i dyno it? i know a very good tuner, that could probably set up a tune on a chip and burn it so we could swap it in after a few base pulls, i would like to stick to the chip tuning approach for now since money is very tight, i could afford a $300 dyno sesion, but how should i have him do the tuning with the chip? and timing? and duty cycle?
not having consult is a big road block
r34 gtr
25psi on some 444s?! Is your fuel pressure at 150psi?
