There is an ECU code for the BPT valve, and my ECU isnt throwing it up. I think my high NO could have been the O2 sensor and improperly routed vac lines.seang wrote:Well, the EGR valve itself might not be bad; but it is regulated by the BPT valve, and I think some electrical relay, I'm not exactly sure. You would have to look at the schematic in the FSM. If BPT valves throw their own codes when they go bad, then I could be wrong. I'm not an emissions control guru.
I can feel it open but just barely. I dont have a vacuum tester..can I just get a long vacuum hose and suck on it, and see if it stays open? While the car is off of course.locoluna825 wrote:If the egr valve is opening around and above 2000 rpms then it should be working. get a longer peice of vacuum tubbing and get a vaccum tester on it to see if it holds a vacuum and stays open.
I would imagine that the vacuum lines being routed wrong would pose a problem.locoluna825 wrote:Yea, Those are your idle air and swirl valve control valve soleniods. that might..... through a code. not to sure myself though. Considering its not technicaly part of your EGR system. but the mixed vaccum lines may cuase a disturbance in the force.
yes, you can. lol i actually dont have a vacuum tester myself and thats EXACLTY what I do. you made me LOL. suck on it and feel for the egr valve to make sure its holding the vaccum vacuum.StryfeS13 wrote:I can feel it open but just barely. I dont have a vacuum tester..can I just get a long vacuum hose and suck on it, and see if it stays open? While the car is off of course.
what way should the arrow point to? The inlet or outlet?Wc240 wrote:yes it matters, there should be an arrow on it. but your passing on the other gasses, so it cant be on backwards. have you tried testin g?swapping the the egr temp sensor(if its a cali model)whats your 02 and co2 at?
I am running premium gas. I took it to smog with fuel system cleaner if that matters. Where can I find out how to do the idle mixture adjustment? I searched it up and believe I found the correct tutorial but I just wanna make sure. Also, when they tested my car, the timing was at 17 BTDC, even though on my crank pulley it lines up with the 20 BTDC mark...Wc240 wrote:by law, its up to you to smog it. unless someone buys it as is for like 200 bucks(really all you can charge) or you can diag it and fix it.\
heres what i recommend,what gas are you running?do the idle mixture/timing adjustment, check the plug gap, ALL TO FACTORY SPECS(very important)
then, take it to a shop,(repair) and have em to a cat efficiancy test( co2 cranking test, hc reduction test, nox reduction test) and see if the cats bad.
or, i advise against this but, just buy a cat and pass it. reason i advise against it is its just a band aid fix. and what ever killed the previous cat will blow that one out too.
cars are money pits, its not becouse the 240 is a bad egg. its cars in general
I set it to 20 BTDC because I read somewhere that stock timing is 20 BTDC, actually I believe I read it on here. And yes of course I unplugged it. Keep in mind I have a dual cam.locoluna825 wrote:what do you mean it was at 20? did you unplug the little harness at the TPS sensor and check the timing? it should be at 15 BTDC.
Yeah, my 02 sensor is replaced. My EGR works and I have replaced all vacuum lines going to an from it.locoluna825 wrote:ok so you timing is down. You fixed your 02 sensor, right? and your egr seems to be working.
Did you recently clear the memory to reset the codes? if you did, do you know you must drive that thing about 55 or more for about 20 minutes to get the ecu readjusted? before you took to be smoged.
i would have to say its the CAT then man. if you still failing
Found out one of my vacuum hoses that run under the intake manifold came off. So I replaced it. I have also replaced every other vacuum hose that looked old or crusty.zer0c123 wrote:I doubt there is anything wrong with the CAT since you have have high NOx. Although you failed HC on the 2nd run you might have a slight vacuum leak that will bring up HC slightly and NOx.
If you have completely ruled out the EGR system, then look for a vacuum leak. The egr system can be easily carbed up after so many years. There is the EGR, EGR-BPT, BPT-pipe, EGR pipe, and one last component that has three bolts where one bolt needs a swivel socket to get to. Also there's two gaskets that you'll want to replace if you take those components off for cleaning. I think the BPT-pipe can easily be clogged since the diameter of the tube is so small.
Also it would help if you posted up all the smog check numbers for everyone to see.
thankslocoluna825 wrote:cool, glad you made some progress. you sure you didnt cross thread it?
um.. what?! lolzer0c123 wrote:I doubt there is anything wrong with the CAT since you have have high NOx.
