Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Apr 19, 2007 5:54 am
I think what he's meaning about the car not being in park is relative to what eneds to be done electronically to get the top to work after a 5 speed swap.
The inhibitor switch needs to be jumpered to trick the ATCU into thinking it's in park at all times, or else the top doesn't go down. It's a necessity on a 5 speed swap, but I would heavily recommend to leave it alone on an auto equipped car.
And as far as leaving the rear 1/4 windows up, you can probably find the wire that tells the logic unit for the windows to lower when the top down button is pressed and sever it. Of course, that may also just disable them entirely. Nissan has a weird way of making their logic circuits dependent on each other.
