Darius, resend you diagram for me, don't think I got it. But what do you mean by upstream?Darius wrote:Makes perfect sense, but on the 1997 it is a little different because the A/C compressor relay is upstream of the triple pressure switch. So what I am proposing to do is jumper the wiring on the F4 plug together to bypass the ECU.
300Plus - I know you have been busy with your AC, but when you get a chance, could you look over the diagram I e-mailed you and give me some feedback? I'm pretty sure it will work the same and I won't have to externally add a FICD wire if it will work by grounding the ECU wire from pin 46 with the Y/B wire.
Darius wrote:Ok sweet. That makes it a lot easier than trying to mess with the existing wiring. All I have to do then is connect the B/P to the P and then both of those to the Y/B to ground the TPS when the AC switch is pressed. Then ground the B to the chassis and run the OR/B to the ground side of the e-fan relay coil. Cake.
If this can be confirmed it would help Darius and everyone. If you can get a SOHC compressor and A/C lines it should just bolt right up to your S13, I don't know if the compressor has the same flange as the S14 lines but either way the lines and compressors should be easy to find here as compared to the skyline compressors and lines!Bwana wrote:I'd like to throw in a random point...
The stock sohc a/c compressor bolts right up to a s2 a/c bracket and everything lines up perfect, bolts, pulley etc.
I don't have the stuff to try a s1 bracket or dohc compressor, but I'd guess them to be the same...
Makes
I think you have that backwards hehehe R134 is current R12 is obsolete.300Plus wrote:
The s13 pumps will probably be R134 collant and I'm not sure if you can just run R12 (today's standard) in them... can anyone confirm that aswell?
