amarokorg »
https://forums.nicoclub.com/amarokorg-u5424.html
Tue Oct 03, 2006 9:31 am
Some of you may have seen my posts in the main forum off and on for a while trying to get my '92 Vert back on the road.
I had a bad injector (resistance not in spec), so I decided to replace all four of them with a set from DeatschWerks.
After the install, the car would barely run. Someone suggested that the lower o-rings on the injectors were missing/damaged and I was pouring gas into the cylinders. Sure enough, popped the injectors out and all four were damaged.
I got another set of o-rings from DeatschWerks and reinstalled the injectors according their recommendations - used clean motor oil as an assembly lube, seat the injector as far as I could by hand, rotate the injector several times to seat the rings, then install the cap turning each screw half a turn on each side until snug. After installing the injectors, the car started and ran great. Shut it down, left it for 3-4 hours, and when I came back, the #1 cylinder wasn't running anymore. Pulled the #1 injector, and the o-ring was in the same shape as the first set! Replaced it with one of the old o-rings from the original injectors (not damaged), and installed it. Now #3 isn't running. Same thing, damaged o-ring. Replaced IT, runs great.
Let it all sit for a few days, come back and #1 isn't running anymore. Pull the injector, same thing, trashed o-ring. Replaced it with another old one, runs fine.
What could be causing these o-rings to fail? This isn't the first time I've replaced injectors, and I'm confident I'm installing them (and the rings) properly. I'm really at a loss to why these keep failing. Other than the old injector that failed mechanically, I never had this problem on the old injectors.
Ideas?
Thanks!
- Dave
