its aged man. like it or not by then internals are worn. i would only suggest doing tanny fluid work at around 30k-ish. past that, and i have seen MANY cars not even make it out of the service bay. everything inside slips like crazy. its a very-very common problem. this is why shops 'warn' their owners. many shops get sued for that and walk out scot-free. its not their fault.ssutphin wrote:I had it done at the Nissan dealer and left it up to him to use the proper fluids. I don't consider 81K miles to be an aged transmission, more like an early middle-ager.
thats not true. the cvt has a system that mechanics plug into, and it tells you a number. that number tells you the condition of the fluid. many times dealership mechanics tell people that around 60k, the fluid is only half 'bad'. this cvt fluid doesnt need to be changed often like atf.lne937s wrote:The major issue with the CVT is a lack of proper maintenance. The CVT fluid is an integral part of how the transmission works, and people need to be better educated and more diligent. These transmissions were not designed to go 80k before a fluid replacement-- it is not the same as an automatic. IMO, the original fluid should have had a drain and fill every other year/every 30k (whichever is sooner).
no its not. read what i wrote above: "parts wear. as they wear, they become veyr smooth. adding fresh/clean fluid into that newly smoothed parts makes them slip. replacing the old gritty fluid allows for friction between parts which results in no slipping. its a common practice in aged transmission's."lulimet wrote:That's pretty ridiculous that the dealer suggested to use the old fluid.
This isn't CVT specific. It's all automatic transmissions that haven't had their fluid changed regularly and early enough.ssutphin wrote:Thanks. Maybe Nissan will resolve this by their next generation of CVTs. This transmission is a great concept but from what I have been reading it does not have very much consumer confidence across the board.
That's not true, the Premium maintenance say's to change the CVT fluid every 30,000 milesssutphin wrote:All that seems to be true from what I have been reading but the Nissan Owners Manual says not to change the fluid until it has 100,000 miles on it. Nissan needs to change their Owners Manual to recommend the change at 30,000 or less to keep their owners from being surprised by this. Knowing what I now know about the CVT I would not have bought this car. The Rogue is a great car that I have otherwise been well satisfied with but I have very little confidence in that transmission.
