That's exactley what I do to keep the radio on after turning off the engine.CoupeSlate wrote:are you trying to keep the radio and other electronics on after turning off the engine?if thats the case, while you are in park with the engine on, push the On button rapidly twice. this should turn off the engine but leave the electronics on uninterrupted
That is correct.CoupeSlate wrote:are you trying to keep the radio and other electronics on after turning off the engine?if thats the case, while you are in park with the engine on, push the On button rapidly twice. this should turn off the engine but leave the electronics on uninterrupted
He meant when the engine was already running. He wants to shut off the car, keeping it in ACC without an interruption.LinkNuc wrote:For the 6M/T its easy, just don't press the clutch in, one push goes to ACC the 2nd to ON.
LinkNuc wrote:oh easy, just let out the clutch real quick...and make sure you don't hit your head on the steering wheel....
Hmmm...I've tried that, but couldn't get it to work. I guess I will try harder.CoupeSlate wrote:are you trying to keep the radio and other electronics on after turning off the engine?if thats the case, while you are in park with the engine on, push the On button rapidly twice. this should turn off the engine but leave the electronics on uninterrupted
lmfaoooo happend to me this weekendLinkNuc wrote:oh easy, just let out the clutch real quick...and make sure you don't hit your head on the steering wheel....
