ke70 corolla ca18det piston slap plz help
ke70 ca18det
Car: ke70 corolla ca18det
hi i am new here
i successfully made some power out of the car...modifications ihivf30 turbo external wastegate mounted on stock manifoldfmic with ss pipings3 cat back avcrsafcstock injectorsstock mafstock ecu stock clutch
i tuned the car on 7 psi safe boost for some nice power ,becuz its a lightweight car
results were better thn a supra 2jz stock..but heard piston slap on number 3...
then opened the motor to findout it was a spun bearing..i had a spare block completely fine only oil pump was finished ...so i borrowed a piston and a bearing from it...i again start the new build ok f9 but after 100 kms same problems.......
i have left some spares such as3 pistons ok and 3 bearigs okand a crankshaft
wht could be the cause ecuoil pump or oulrod bolt plz help
ke70 ca18det
ordered some parts cp pistons stock bore 83 with 8.5 crcometic gasket 1.2 mmnew oil pumpacl race bearings std size
parts i have spec stage3 plus clutch kitjun lightweight flywheelhks ssqv black editioninnovate lm2 wide band controllerhks eids controller for stock ecu bov vent
my power goals are 350 to 400 bhp not whp
will the stock rods support it with new cp pistons
correct me if i wrong ....i tried this ihivf 30 from subaru car barnd new turbo but worked very well on ca18 at least better then t 25 and t28s
boost_boy
ke70 ca18det wrote:ordered some parts cp pistons stock bore 83 with 8.5 crcometic gasket 1.2 mmnew oil pumpacl race bearings std size
All of those parts look good on paper, but what are you doing for an engine management system? Your engine could've failed again for a number of reasons, so I say build it right and repair or replace the parts that are suspect. The stock rods will support your power desires.
Dee
float_6969
Have you checked oil pressure? Are you sure that the oil gallery going to the 3rd bearing is OK? Have you had the crank checked out, maybe the journal on the 3rd bearing is out of spec?
