Kat vacuum problem
boost infested
Car: cars, chicks, food, and .....
if i start up the car cold, i get 16-18 in of vac. then it would go to 5in of vac but the idle stays the same. by touching the gas pedal i get 16-18" vac back but it would stay for very long.
do i have a leak? air sensor is ****ed?
the car fell on its face yesterday when i try to take off from a stop, cause it wouldnt rev pass 2000rpm. i shut the car off for about a few minutes and shes back to normal(still having the problem above).
what should i check for?
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Pressure check piping and intake manifold...use and air compressor.
Block turbo inlet with a soup can or other ~3" diameter object, the hook the air compressor up to any vacuum line, and pressurize to 10-12psi...you'll find the leak.
- Brian
andrave
Car: 1989 Nissan 240SX Coupe
yeah be careful to watch the pressure, you can blow out the bov seals if you jack up pressure.
boost infested
thanks, i will check it tomorrow.
