LongIsland240 »
https://forums.nicoclub.com/longisland240-u11282.html
Sat Dec 20, 2003 3:24 pm
[QUOTE]Originally posted by ftrs13 "]1. when removing the aiv valve, there are 2 vacuum? hoses that connect to a sensor on the mounting bracket, are they necessary to keep, can I plug them up or connect them, or should I keep the sensor on the car.
you can actually remove them completely rather than plug them. They go back to ports under the throttle body, just take them off and put some vacuum caps on.2. Im going to have to put a pretty big angle on the oil return hose, is this going to cause I huge problem? I know that it should be gravity induced, but there just isnt enough room under the turbo on the motor mount.
Not to be mean, but that looks like kind of a poor spot to mount the turbo.....good luck with the drain, i top mounted for the best clearance. You may want to reconsider if it's only tacked right now.
anybody with a z31 turbo on a KAe, or de, how did you mount it, mine ended up low, I was just curious?
Yes, on a de, and the first thing i realized was a change of the turbine housing/outlet elbow would be in order. several reasons for this included- i like steering and a/c, i would have ended up with a rigged looking install rather than a clean one, and i couldn't find a flange that would fit the outlet- it looks like a regualr 3" but it isn't....took it to every exhuast shop around tyring to find anything that would fit. Anyways, i got a new .63ar housing with internal wastegate that has a standard 3 bolt outlet - this solved all the problems i was having wiht fitment- cost me another $160, but saved my install. Oh, and you can't just change the wastegate/elbow portion because regular t3 turbines use 5 bolt housings, not 7 like it is now.
