C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Dec 24, 2003 5:14 pm
Driving on a race track takes driving to a whole new level. Regardless of how well you think you can drive on the street, everything changes on the track. Few people havce such reserve as to humble themselves before they get out onto a track. Track racing puts more stress on the car than any other racing I know of. Consider that everytime you are doing anything, you are trying to use the car's full potential. The motor, brakes, and suspension(especially tires) are truly put to the test. All you need is for your brakes to fade and you not to realize they are fading to put yourself into a wall. And with a turbo, you car will hit higher speeds, particularly in long straights. This will require you to brake more before entering a turn. OEM brakes are barely adequate for even some slower tracks. A turbo will considerably make things worse. Consider it a way to work out any bugs in the suspension and brakes to ensure that your car will be in good working order to handle the strees of having more power. These are the more important things on a track anyways. And even without a turbo, road racing is quite fun.
I've heard several stories of people rolling or destroying their cars their first time out on a track. To name two, there was a WRX that I heard some kid rolled. I guess he though AWD meant he can go as fast as he wanted through a turn. The second was a Acura CL. This one was a kid who basically ran off the end of the back straight on the streets of willow. The turn entering this straight is a banked increasing radius turn that basically allows you to slingshot your car down the straight. It leads into a blind downhill chicane. Well, he launched the car about 20 feet in the air and when he landed in the dirt, all 4 tires blew, the suspension bottomed out and not one panel was left straight. Keep in mind none of the panels hit the ground, which means all the bending was because the frame bent so badly.
The point is, you can't get into any kind of racing with the mentality that you can handle a certain amount of power, regardless of what you've driven before. Driving something on the street and on the track are very different experiences. It's a lot of fun. Unless you wreck your car. And keep in mind, most insurance policies do exclude damage that occurs on a race track.
