fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Fri Feb 27, 2004 2:08 pm
as far as picking something to manage your fuel, you need to decide how far you want to take this car. Are you going to want to up the boost later on? At 7 psi, you're right on the edge of where most people say it is acceptable to use a rising rate fuel pressure regulator (RRFPR), which will bump the fuel pressure per pound of boost, giving you the fuel you need. After 8 psi or so, its pretty much agreed that you are going to want something a little more advanced. You will need a BTM along with this also.
If you want to go higher than that - depending on how high you want to go - you can consider doing a S-AFC + BTM combo, or possibly a JWT ECU. There are a lot of different options you can do, and they all have their pros and cons.
Here's a list off the top of my head in no particular order:
1. MSD BTM + RRFPR2. MSD BTM + S-AFC3. RRFPR + Retarded Base Timing4. S-AFC + Retarded Base Timing3. Hacked MAFS (s14 only) + MSD BTM4. JWT ECU5. Greddy E-Manage or Similar Piggyback6. Extra Injector Setup + MSD BTM7. Standalone Setup
There are probably even more that I'm forgetting..
