kat part list
1991ls13
Car: s13 ls1 hatch
i know i`ve seen some parts list for the going kat and the thread about going kat, i`d just like advice for a certain set up.
i`m looking for about 400-450 whp on pump gas with about 15-18 psi
i have to rebuild my motor so i was wondering what i should upgrade since its going to be a dd.no i dont want to do a major budget but if there is a way to do it cheaper without a huge quilty loss would be great.
this is what i was thinkingforged pistons eagle rodscamsgt35 turboidk what kind of injectors
please any info about a complete set up of list on parts that would be great
and for the price of everything, would it be cheaper easier or better to just do a 1jz or something when i can get the complete motor and transmission for 1800-2000 bucks?
thank you
leonelrr
Car: s13,s14, z32TT, YZF R6 None of them work nothing to brag about
From my perspective and things i've learned from reading here and helping some friends..I've learned that is not just about slapping a turbo and call it a day.
I see you haven't talked about studs, for instance and gaskets..
Here is my list ERICKS PERFORMANCE PARTS LIST:
ARP Main Stud Kit Nissan KA24DE 240sx S13 S14 Altima 116.00ARP Rod Bolt Kit Nissan KA24DE S13 S14 240sx Altima 42.00ARP Head Studs Nissan KA24DE 240sx S13 S14 Altima 125.00Cometic Head Gasket Nissan KA24DE 240sx S13 S14 KA24 89.00Bore Size: 90mmThickness: 1.2mm
TOTAL: 372.00
Nissan OEM Water Pump KA24DE S13 S14 240sx KA24DET KA24 78.00Nissan OEM Oil Pump Front Cover KA24DE 240sx S14 KA24 280.00Nissan OEM Oil Filter KA24DE S13 S14 240sx KA24 KA24DET 15.00OEM Nissan KA24DE Timing Chain Tensioners Guides Set 341.00
TOTAL: 714
I hope it helps you... Now what would be better then what? Depends on your abilities or money you have to tune it i guess?
Note that this list is still missing the main bearings, and lower and some other gaskets..
Did i also mentioned some better titanium valves? Valve seats, springs ..
And the cost from the machine shop.. Port and polish?
Injectors i guess the 72lbs? Or if you are willing to go with a aftermarket fuel rail..
Good luck
1991ls13
Car: s13 ls1 hatch
thats alot of info, thank you for your time and help.i was just seeing if the 400-450 goal would be easier to get and cheaper if i went 1jz.
but over all i called around and in sac i found a shop that had a drop out ls1 and t56 transmission.i got it for 2675 only has 50k and a warranty so i figured why not. let go with the ls1.
thamk you again
