Engine and Transmission: 750Ross Pistons: 489Pauter Rods: 689Turbo: 700Wastegate: 300Exhaust Manifold: 400Machine shop work (clean up, bore, hone, valve job with guides): 400S-AFC II: 280300zx 370cc injectors: FreeFuel Pump: 100Clutch: 300Exhaust: 300Headgasket: 100 (stock one should work for what I'm doing)Fuel Pressure regulator: 100Incidentals (bearings, bolts, random crap): 400
This puts me at: 5308
I would tune it on a dyno and up the boost until I got to about 90% duty cycle on the injectors and call it quits. I'm guessing it'd be 11-13psi. Oh, and I forgot to mention...I allready have a fmic, bov, vlsd, and 300zx MAF. I've searched and read up on the KAT and I think it's doable for this much if I do the labor all myself. Thanks for the opinions I'm sure are to come
